Twinthesis : Twitter Powered Synthesis for the Mac
dazed
Post by dazed »
"Twinthesis is a MaxMSP patch I designed to explore the ‘sound’ of twitter, in an attempt to sonify the human randomness being generated on the service. This post is a quick overview of the synthesis engine, as well as a quick video outlining the features and concepts behind the patch. You can then download the synthesiser as a Mac application.
The aims of this project, are to create a synthesiser capable of both additive and granular synthesis using live tweets to generate and manipulate the sound. The synthesiser currently calls twitter once every 30 seconds, so a new tweet is used to generate the sound every 30 seconds. The synthesis engine, has an element of performance to it, and can be used to create experimental music."
http://samharman.com/
