Yosemite Install Drive
Karlos
Post by Karlos »
Hi.
As the subject line suggests, I want to make an install drive of Yosemite.
I haven't a 8GB USB handy so partitioned 20GB of an external drive.
I'm thinking about using the "DiskMaker X 4b4" to simplify the job...
https://youtu.be/bQurLY61EtA?t=3m28s
The question I have, is how do I download Yosemite on a system I don't want to install it on?
All I get in the App Store is a button to upgrade to Yosemite, I want to download the whole thing to do a clean install on an external Hard Drive. I want to build a eternal system to make sure even thing is working right before I copy the drive to my Mac's hard drive.
So how to I download the whole install, and not install it so that I can use it to create an install disk.
In Christ Jesus, Karl.
Lurkanadian
Re: Yosemite Install Drive
Post by Lurkanadian »
Just download it here.
It's 5.6 gigs, so depending on your connection it may take a while.
After it's downloaded, move it out of the Applications folder to another drive or partition.
"At least when they took you to Auschwitz, your killers had a face." ~ Otto Boners
cunty_baws
Post by cunty_baws »
\i/ oo
“You can safely assume that you've created God in your own image when it turns out that God hates all the same people you do.” - Anne Lamott
cccc
Post by cccc »
Otherwise you could always turn to the local Apple expert in your neck of the woods...Ceebs :mrgreen:
"Everything has been figured out, except how to live."
- Jean-Paul Sartre -
